  • No se cual es mi usuario y contraseña
  • Using Veyon across VLANs
    @paulthedate Answer was I needed to use the IP instead of Hostname in the Configurator. now all good.
  • trouble import keys
    @tobydox https://prnt.sc/1e1d6oj I have a problem I can't import the key so it appears
  • .pem
  • Veyon ne fonctionne pas sur mes pc ??
  • Problems with gdm but not with lightdm
    Hi, The way to fix this problem : install the lightdm package on the PC running gdm select lightdm option during installation reboot Juste one question : For which reason does the command "telnet localhost 11100" is OK just after the lightdm installation and not before with GDM ??? V.Le Mieux
  • What is the Cli command to set PredefinedPrograms
  • Better Documentation Please
  • Is it possible to connect from my home to the classroom?
    @tobydox Not technical enough! Does not the entire internet work through TCP/IP? That's like saying that you can listen to the radio, as long as your radio can pick up the electro magnetic waves. Though I suppose the caveat "directly" offers some clues. I suppose you mean to suggest that the IP route is unobstructed, and not behind NAT or firewalls, right? Can you elaborate on the security risks or design paradigm a bit? Is all I have to do is forward the 11100 and 11400 ports?
  • How to upgrade?
  • Dialog boxes via Veyon not rendering
  • Connection problems - long waiting times
    Are you using key file or logon authentication? In case of logon authentication the bottleneck could be your AD server since it has to handle authentication requests from all Veyon clients at the same time (since each client checks the credentials of the teacher to authenticate the connection).
  • Issues using veyon-cli authkeys import
    @erict: indeed the authentication key name check is too strict at the moment since it only allows word characters (0-9, a-z, A-Z and underscore). I just committed a fix which will also allow the minus character (https://github.com/veyon/veyon/commit/768feeb53c11d7a1f5e5fa4d8378d795c73cc1ad). It will be part of Veyon 4.5.7 next month. In case you build packages on your own, you can simply do this for the latest 4.5 branch. Besides that, importing keys via veyon-cli should work with the following command: veyon-cli authkeys import veyon_master/public public-key.pem
  • Red screen on desktop preview?
    A red screen usually indicates authentication problems, i.e. either the authentication keys have not been setup properly on both teacher and student computers or logon authentication fails due to invalid credentials entered on Veyon Master startup.
  • Unable to setup Active Directory in Configurator 4.5.6
    @stuartr Interesting! Does it work with 4.5.5? I'm asking because we upgraded the 3rdparty OpenLDAP library in 4.5.6 so the crash might be related to that.
  • Veyon keys not setup properly Ubuntu 18.04
    11
    H
    @tobydox I don't see where to add the parameter. I switched to advanced mode, under "service" I don't see any place to add a parameter under the VNC server section.
  • problem with vertically placed screens
  • Veyon 4.5.4 VNC serveur Crash on demo mode
    30
    5k Views
    Hello Tobydox I now know the problem of error 87 ... but I don't know how to solve it yet ... the error occurs if I am connected in RDP on the machine on which I am installing Veyon. if I am physically connected to the machine no more error 87 problem. From the information I could read, this is related to graphics driver problem ... But you have necessarily done something about the graphics settings since until version 4.5.4.3 this does not pose a problem in RDP. Fred
  • LDAP Configuration for user access
    Have you installed all available Windows updates? The AcceptSecurityContext call has been an issue with certain updates 1 or 2 years ago. As a workaround you can enable the Use alternative user authentication mechanism option in the Windows configuration page in Veyon Configurator after enabling the advanced settings (View -> Advanced).
  • Crashes when a computer in the Locations/Computer list is clicked
    FYI: the issue has been fixed in Veyon 4.5.6.
